- 15 Nov 2007
Hi all,thought i would try S.T.A.L.K.E.R so ive purchased the collector's radiation edition for £14,i want to install the weather overhaul mod but finding the install instructions a bit unclear.
INSTALATION:
0. DELETE the float32 shaders ([gamedata] > [shaders] folder) prior to use this version of my mod
0.5 delete (move) the [gamedata] > [textures] > [sky folder] if you have it in your Stalker installation dir - do it also if you are updating form 1.1
1. copy the gamedata from the [#1 - S.W.O.v2.0] or [#1 - S.W.O.v2.0_SL] (Static Lighting) > [#base] folder to your main Stalker installation dir (after this you will have the darker nights edition - which is default) - overwrite everything if you are updating from 1.1
1.5 OPTIONAL: copy over the gamedata from the [#1_-_S.W.O.v2.0] or [#1 - S.W.O.v2.0_SL] > [#optionals] > [#brighter_nights] - to make the nights brighter (you can revert to the darker nights by using the gamedata from [#darker_nights] folder)
2. copy the included user.ltx of your choice from the [#2_-_[user.ltx]_presets] folder into [documents and settings] > [all users] > [documents] > [stalker-shoc] (you will have rebind your keys and re-set other in-game settings after this)
3. OPTIONAL (S.W.O.v2.0_FULL only): copy over the gamedata from [#3_-_S.H.A.R.P.E.R-Textures_v.0.95_RECUT] to your main Stalker installation dir
NOTE:
if you did not install or use any mods previously - in the fsgame.ltx (main STALKER dir) change the first line into:
$game_data$ = true| true| $fs_root$|
Above are the installation instruction's in the readme file,now it say's to delete the float32 shaders which i pressume are in the gamedata file?only problem is i have a couple of gamedata files but cant open any of them,it say's the files are to big,any help will be much appreciated thanks guys
INSTALATION:
NOTE:
never had problem's with this type of thing before
