I currently have a I5 2500K on air using a Geil tranquillo v1 I get about 37 on idle and about low 70's on load with it overclocked to 4.2.
I am thinking of upgrading to a I7 2700K or I7 3770K and would like to purchase a water cooler.
My first question is my current cpu cooler enough to use for either of these cpus without buying a water cooler ? If not then what would be the best budget option water cooler to use ?
https://www.overclockers.co.uk/corsair-hydro-series-h45-performance-liquid-cpu-cooler-hs-039-cs.html
https://www.overclockers.co.uk/cooler-master-seidon-120v-ver.2-liquid-cpu-cooler-hs-062-cm.html
https://www.overclockers.co.uk/antec-h600-kuhler-120mm-aio-liquid-cooler-hs-013-an.html
I have only enough space for 1 x 120mm fan so i can't use dual and price is very important due to the high cost of 2nd hand cpu's.
can anyone please advise ?
Cheers
Dan
Cheers
Dan
