- 4 Oct 2011
- Newbury, UK
Hi guys,
I am looking at water cooling my PC for the first time, crapping it and looking at parts I think I might need. This is what I have come up with and basically, will it work?
YOUR BASKET
1 x EK Water Blocks EK-D5 Vario X-RES 140 (incl. pump) £107.99
1 x EK Water Blocks EK-FC980 GTX - Acetal £79.99
1 x EK Water Blocks EK-Supremacy EVO - Acetal (Original CSQ) £49.99
1 x EK Water Blocks EK-CoolStream PE 360 (Triple) £49.99
1 x MagiCool Copper Radiator - 280 mm £31.99
1 x XSPC Razor GTX 980 Backplate £21.98
1 x Mayhems X1 UV Green Premixed Watercooling Fluid 1L £7.99
10 x EK Water Blocks EK-ACF Fitting 12/16mm - Black £3.79 (£37.90)
2 x XSPC 7/16" ID (16/11mm) High Flex Hose - Clear (1m Length) £2.99 (£5.98)
Total : £403.43 (includes shipping : £8.00).
I have brought a EK mounting 120MM bracket to mount the pump/res to the 360mm rad
Any help would be appreciated.
YOUR BASKET
. Also the tube is securely on the GPU yet looks like it is coming off. think it is the bend in the tubing. Unfortunately the pump/res turned up damaged so I am having to return that. I have a couple more 90 degree fittings turning up to sort out the area around the input into the 360 rad to limit the amount of tubing
