New to watercooling need help
18 Jun 2014
Hi I have a i5 4670k and a reference r9 290 I'm getting really high temps from the gpu and was looking to water cool my system. I'm new to water cooling and was looking at buying this kit
http://www.overclockers.co.uk/showproduct.php?prodid=WC-265-XS&groupid=962&catid=1532
Will i be able to use this kit to also cool my gpu? Was also looking at this water block for my gpu
http://www.overclockers.co.uk/showproduct.php?prodid=WC-463-EK&groupid=962&catid=1520&subcat=2765
Like i say im new to this and any help or advice or another suggestion would be much appreciated
That does look like a good bit of kit the only thing is my case supports a 240mm radiator is there any other 240mm radiator that gives the same efficiency as that one in your link? Also this might seem like a silly question but is there any problem with running the radiator out side of the case and just have the tubes going into the case? Thanks also for the reply
You can have an external radiator, no problem. I did on my previous build, and will be doing so againonce I add my new gpu's in to my loop. You also will need to get extensions to your fans power leads also.
I have my external rad sitting on a rad stand, connected to rest of the loop via a couple of Koolance Quick Disconnects so that I can move the case and rad independently for any maintenance etc. having everything internally does indeed look tidier, but in certain cases it isn't possible and external gives you a versatility.
Any further questions in this regard, let me know.
