** NEW ** Top quality desktop microphones. Better range, better value
22 Aug 2010
Due to popular demand I have introduced a new fresh range of microphones.
Perfect for web applications such as skype, MSN Messenger, Yahoo Messenger and many more. Also perfect for gaming communications Ventrillio, TS3, Mumble, Xfire chat.
DON'T MAKE YOUR TEAM LOSE BECAUSE YOU'RE NOT COMMUNICATING! :)
Logitech Desktop Microphone (980240-0914) @ £13.98 inc VAT
Chat or Record your thoughts without sharing all the background noise as the Logitech Desktop Microphone blocks all unwanted noise. Enjoy the look, pivoting design and quality of this desktop microphone with nearly any computer. To keep it simple and for your convenience the mute switch give you privacy whenever you need it. The microphone is mountable to the monitor or you can keep it on the stand. Setup is easy just plug into the microphone input.
- 3.5mm Jacks
- Noise-cancelling mic filters out unwanted background noise
- Pivoting base to hold preferred position
- 2-year guarantee
Only £13.98 inc VAT.
ORDER NOW
Logitech USB Desktop Microphone (980186-0914) @ £19.99 inc VAT
Acquire superior audio quality with Logitech’s USB Desktop Microphone. It incorporates a noise-cancelling mic and provides easy plug and play operation. Its design is sleek and compact for any desktop and works on PCs and MACs. The microphone pivots easily on the base to hold a preferred position.
- USB Desktop microphone for PC or MAC
- USB plug and play connection
- 2-year guarantee
Only £19.99 inc VAT.
ORDER NOW
Speedlink Spes Clip-On Metal Microphone (SL-8691-SBK) @ £7.99 inc VAT
The microphone is attractively designed and is extremely practical. The noise-suppression system filters out bothersome background noises and makes internet chat easy and uncomplicated. Furthermore, the clothing clip allows you to clip the mic anywhere you like.
- Lots of freedom of movement thanks to the 2.4m cable
- You'll hardly notice you're wearing the mic thanks to it's low weight
- Easy to attach to clothing thanks to the clip
- Highly sensitive microphone featuring noise suppression
- Robust design made from black metal
Only £7.99 inc VAT.
PRE-ORDER NOW
ORDER NOW
Speedlink Puri, Pure Voice Microphone (SP-039-SL) @ £7.99 inc VAT
The Pure Voice Microphone is attractively designed and is extremely practical. Noise reduction filters out intrusive background noise and the flexible adjustable neck allows the microphone to be positioned at any angle. The stable base ensures it stands securely.
- 2m cable
- 3.5mm jack plug
- Weighted base plate for stability
- Flexible adjustable neck for full adjustment of the microphone angle
- Noise-suppressing microphone filters out background noises
Only £7.99 inc VAT.
PRE-ORDER NOW
I have one of the Speedlink clip-ons, very unobtrusive to wear and very good pickup quality too, I'd recommend it to anyone who isn't partial to headsets.
I've been using the Logitech 3.5mm jack model for some time and it works brilliantly for me, if a little sensitive.
I have the Logitech USB model and its a great mic for the price, no complaints, could have done it all black like the other model though :p. Will allways been headphones and separate mic in the future fo me.
In my experience gamers prefer to use a headset with a mic on it, dont get feedback
and stuff either.
Headset with mic on it is okay, but I'm currently using a large surround sound system so been on the lookout for a mic for sometime.
Been using one of the 3.5mm Logitech's over the weekend I bought last week when these came in, seems to be doing the job okay as the guys in TS can understand me again...
There is nothing worse than a muffled microphone!! I was having a match in Cod4 on the weekend and a guy in vent had a microphone which sounded like he had a pillow over the top.
So... what's up with the ETA on the clip-on mic? I pre-ordered and it seems as though they are overdue :(
Will they be in stock soon?
