New ultrawide monitor
30 Nov 2016
Hi all,
I've looking for something to replace my Predator X34 which has been great. In terms of what i'm looking for
Ultrawide again
at least 144 hz (mine currently only overclocks to 95 hz and is the main reason i'm upgrading)
as low an input lag as possible
34 inches again to fit my other monitors
Price ideally £1,000 ish. Can go more, obviously less is better.
In terms of hardware i'm currently on a 7700k and 1080ti but will be getting the 3080 ti (or whatever it is called) when I can.
Thanks all!
LG 950G/F or Alienware AW3420DW are about your only options atm. The AW does 144Hz I think, the LG only 120Hz if memory is right. 3418DW also good, but older model.
Thanks all. Always amazes me how slow monitor tech seems to move compared to everything else. I've had this thing for years.
I came from a 165 hz 27 inch to this and definately noticed the difference. Monitor will be around for a longtime and be driven by 3080 ti etc. so want to get something that does it justice.
I mean that Iiyama, seems too good to be true?
In terms of the below guess i'm losing HDR (not impressive on pc anyway from what i understand unless you go all out) and a few hz.
https://www.overclockers.co.uk/lg-3...-led-curved-backlit-gaming-mon-mo-15l-lg.html
I really wouldn't worry too much about HDR on a PC Monitor at the moment. Implementation is sketchy at best, downright terrible at worst. If HDR is important then OLED is really the only way to go, and that's ££££££ for a dedicated PC Monitor. If you can find one.
