New USB Standard
20 Amps through tiny USB connections? I don't like the sound of that. Might be better if it were 12v rather than 5v I suppose.
new electronically detectable certified cables will be required for higher power transfer.
i like the fact we can power external drives and laptops, but surely we'd need more expensive cables and psu's
And not forgetting the mobo traces will have to carry that 20 amps to each usb. I can't see any more than 2 20amp sockets on a motherboard.
It has to switch voltage up, 20amp isn't needed on such a cable. Even laptops charge on 3.5A. I imagine it will scale to 20V 5A or there abouts.
Aye, I read it. Doesn't state it won't either. What devices need 20A at 5V? The article specifically mentions laptops, even netbooks currently (snarf) charge at least 12V, most commonly 19V. Who wants to lug HT leads around with them?
...This allows some very interesting possibilities, the most intriguing is getting rid of charging ports entirely, and having every USB port, with PD support of course, capable of powering the laptop. Or powering another laptop, monitor, or anything else. Or none of the above, and not catch fire while doing any of it, quite a trick when you are talking about pushing 100W over a thin USB cable.
Much of this is possible because the PD spec requires and detects PD cables, both their presence and whether they are normal or micro-USB connectors. Why? PD specs 5A over the wire safely for full sized PD cables and connectors, 3A for micro-USB PD cables. If you are math capable, you might have noticed that to get 100W with 5A, you need to have 20V.
That would indeed be the case, PD specifies, but does not require absolutely sticking to, six profiles for power. The intent is to deliver between 10W and 100W in steps that roughly double the one before. These six profiles are cleverly named Profile 0-5, with 0 being reserved.
Profile 1 is 2A@5V or 10W, roughly what Gigabyte delivers now on their 3X power boards. From there, Profile 2 is 5V@2A or [email protected], Profile 3 is 5V@2A or 12V@3A, Profile 4 adds 20V@3A to it's predecessor, and Profile 5 bumps the 12V and 20V to the full 5A.
http://semiaccurate.com/2012/07/23/100w-over-usb-is-here-with-the-new-power-delivery-spec
Just noticed more info on Semiaccurate. If you were hoping for 20A of heart stopping power, prepare to be disapoint :(
Talking of power through USB. Im still yet to check if my always on usb ports work on my pc. Thanks for the reminder!
