- 21 Jan 2012
- Hereford, UK
So guys its upgrade time I have a corsair air 540 and while its a great case everything is a bit cramped. I have 3 rads on custom loop and the airflow is suffering as its all rammed in there and loops messy
So I'm looking for a new case have £200 budget wanted the 900D but a tad pricey so I'm looking at 700D or phantek enthoo the £199 one
Basically want a large case so everything looks neater and more spaced out will be having hardline tubing
Would like a window case to show it off either two I mentioned any good as going off pics is hard
Or suggest some you think would be better thanks guys
