New water cooling case
24 Aug 2003
Gillingham Kent
Want to get a new case. Water cooled internally and use the TFC Quad Radiator 480.
Now looking at the cases it appears to me that the Lian Li Armorsuit PC-P80B fits the bill.
I would mount the rad in the front with my XSPC Single Bay Reservoir and
optical drive above/below it. Can you forsee any problems with this set up or recommend a different case?
Gary
How about this case instead? Lian Li TYR PC-X2000 Aluminium Full-Tower
Hi,
I have just recently finished speccing my new build which is to include two of those rads. The case I chose and is currently being modified for me is a Lian-Li PC-V2010A.
I'm having one rad cut in the top ( Case is 590mm deep and the rad is 523mm ) and having the second installed in the lower bay having a mesh section installed in the side like the bottom of a side pannel from a TJ07.
I should be getting the case next thurs-fri, I can post some pics if you like .... although it will be rather empty for now anyway.
Gary
i don't think if you fit that rad in the front of the p80 you'll have room for anything else
Its a shame you can't hold the rad up inside the case and try it. But for that you would need to buy it or work for OCUK
