new water cooling help
30 Dec 2010
hi im starting to look into water cooling for the first time hoping you guys can lead me in the right direction.
im looking at getting a corsair 760t case so should have plenty of room for rads etc. ideally i want to go with a drive bay reservoir (just like the look of them). i have a i5 1155 socket i believe on an msi board. graphics card is a msi twin forza 560 ti.
so i know i need a block for the cpu but what about sb/nb blocks are these specific to certain boards or universal? can you also give me some suggestions. as far as the gpu goes i havent mannaged to find a full cover block. so if i fit just a partial cooling block do i need to do anything to cool the rest of the card?
sorry if this has been covered before just want to make sure i get this right
Honestly Dave, I'd look into investing your money into newer hardware, than spending a few hundred £ on cooling older hardware.
As for your questions though, most motherboard blocks are made for specific boards - mainly the highest end ROG and Gigabyte boards. You can get universal blocks for lower end boards, but they don't really offer any benefit over stock cooling.
If you get a universal GPU only block for your graphics card, then yes you will need small heatsinks and good air flow for your memory/mosfets.
also im after a drive bay reservoir any recommendations? which make water block are the best or are they all fairly standard performance wise?
