New water cooling system/ radiator mount help
31 Mar 2013
Xspc do a radiator mount stand that you may find useful, will only work with the XSPC AX rads though and you could always use the koolance quick disconnects so you can disconnect it for travel etc.
http://www.overclockers.co.uk/showproduct.php?prodid=WC-187-XS&groupid=962&catid=1523
as above or try these (I know they are out of stock):
http://www.overclockers.co.uk/showproduct.php?prodid=WC-093-EK&groupid=962&catid=1523&subcat=1545
I had a thick 360mm rad screwed to the underside of my desk using a rad stand. Here is the stand I used:
Hi just make your own stand or l have my rad hanging down the back of my desk mounted about 3" of the back for air to circulate, using two screws and two long tie raps.
