hi all
i now have a new corsair 760t and am looking to start sorting out water cooling it. current pc spec
- i5 2500k over clocked
- 2 x gtx 670 with heatkiller cooling blocks
- evga supernova psu
msi gd65 motherboard
so i already have the gpu water blocks sorted. although im not sure how to do the pipe work to two gpu's and make it look good.
ideally i would like a bay res purely because i like the way they look. any recommendations? what pump should i be looking for?
what size radiators will i need? and which brand do you recomend
and will i need to do two loops or with one loop for the whole system be ok?
ive been looking at xpsc cpu blocks are they any good? or can you recommend something different?
im hoping that i can pick up some of the parts ie. res and pump second hand. apologies for all the questions this will be my first watercooled build
