New watercooling + case combo
13 May 2007
Lancashire, UK
I'm looking to replace my current case so I thought I would also try and get watercooling going again at the same time to reduce the noise the thing produces. I ideally want everything to be internal so I know I'm going to need quite a big case, but as far as looks goes as long as its not a big ugly box I'm not fussed.
It needs to be able to cool both my i7 920 running a decent OC plus an ATI HD4870. The case will also need room for a fan controller, single dvd drive and at least 2 HDD with the WC kit fitted.
Now for the parts list which I'll update as I find bits I want.
Case -
CPU Waterblock - EK Supreme i7 Clear Top
VGA Waterblock - EK HD 4870 Acrylic Full Cover
Pump -
Resevoir -
Radiator - Thermochill PA120.3
Fans - (Want lower noise than temps really)
I already have the radiator sitting spare so that needs to stay but then this leads to problems with the space availale in most cases. So then, anyone able to help me with the above ? :D
Case - Silverstone TJ07
Pump - Laing DDC1 Ultra 18w
Fans - Yate Loon SL's
Res - depends on your fitment style, bay or pump top?
the fan spacing on the pa120.3 is different to that on the top mount for the haf932, you reed a tfc360 or an xspc rx360 to go with that case
these are the ones I think will mount properly to the top of the haf932
I had seen the TJ07 mentioned a lot but I wasn't sure if they were even available anymore.
I'm not too fussed on where the res goes in the end but I do generally prefer bay mounted ones because they look nice from the front of the case. Had just a plain perspex one before and it looks a bit boring so something that looks a bit nicer would be great.
