After 12 years of air cooling I've finally decided to take the plunge (hah!) into the world of watercooling with my new 3770k build this Christmas.
I'm going to be building a new system centered around a Xigmatek Elysium, Intel 3770k, MSI 7970 Lightning and a ASRock Z77 Extreme6. Based on lots of reading I've more or less decided I wanted a bay res, dual d5 pumps (redundancy more than anything) and to mount a 420.3 in the top of the Elysium and a 240.2 in the front.
With that in mind I've come up with the following:
YOUR BASKET
1 x Hardware Labs Black ICE Radiator SR1 420 £89.99
1 x EK-FC7970 Lightning - Acetal+Nickel £79.99
1 x Koolance CPU-380I Water Block (Intel Processor) £59.99
1 x Hardware Labs Black ICE Radiator GT Xtreme 240 £56.99
2 x Alphacool Laing D5 Vario Pump 655 - NO TOP £56.99 (£113.98)
1 x Aqua Computer Aquabox Professional 5 1/4" - Black £34.99
2 x Lamptron FC5 V2 5.25" Bay Fan Controller - Black £34.99 (£69.98)
2 x Corsair SP120 Performance Series High Pressure - Dual Pack £25.99 (£51.98)
6 x Phanteks PH-F140TS 140mm Fan - Black £16.99 (£101.94)
2 x Bitspower G 1/4" Black Sparkle Triple Rotary 90 Degree G 1/4 Male to IG 1/4 Female Fitting £16.94 (£33.88)
1 x Bitspower G 1/4" Black Sparkle Rotary Angle Fitting - 1/2" £13.94
1 x Bitspower Black Sparkle "T" Fitting - 180 Degree Water Cooling Accessory £9.98
1 x Bitspower G 1/4" Black Sparkle Temperature Sensor Stop Fitting £8.99
1 x Bitspower Black Shiny Sealing Plug - 1/2" £7.94
2 x Bitspower G 1/4" Black Sparkle 45 Degree IG 1/4" Adapter £6.98 (£13.96)
2 x XSPC HighFlex Hose 7/16" ID, 5/8" OD, 15.9/11.1mm, 2m, Blue/UV Blue £5.99 (£11.98)
1 x Mayhems Biocide 10ml With PH Testing Kit £5.99
3 x Mayhems Ultra Pure H20 Watercooling Fluid 1L £4.99 (£14.97)
1 x Mayhems Fine Silver Kill Coil £4.5
15 x Bitspower Premium G1/4" High Flow 1/2" Fitting - shiny black £3.98 (£59.70)
2 x EK UNI Holder 50-70 - Black £3.98 (£7.96)
1 x XSPC PSU Bridging Connector (24 Pin) £1.3
16 x Koolance Hose Clamp for OD 13mm (1/2in) £0.89 (£14.24)
Total : £881.83 (includes shipping : £10.50).
Wasn't too keen on the XSPC res/pump combos so decided to stay clear of them but have some questions on the other bits:
1. Unsure what make of tubing to get. Any stand out brands that I should be looking at?
2. Is the bay res I've chosen big/good enough? Any others I should look at? I'm not a fan of plexi though!
3. Biocide or silver kill coil? Or can you use both (I'm guessing not?)
4. What's the best form of clamp for the barbs? Using 7/16 ID tubing, but would also like clamps as I'm just not that brave for my first build
5. Pretty set on the 120mm Corsairs (unless there really is something better?), but unsure on 140mm fan to go for.
6. Anything obvious missing???
Should be a fun week next week
YOUR BASKET
