Hi guys and gals!
Im about to purchase a new watercooling system for my PC. At the moment im running a reserator 1 plus but its a bit cack and the pump is dying.
Ive found what i (think i) need from the OcUK shop but since this is my first DIY watercooling system where its not just out of a box some assistance is needed.
Here is what ive specced up so far:
Id like a chipset cooler however these DFI Lanparty boards have the southbrige right underneath the graphics card so theres no room!
Im sure ill have to add on some connectors for the radiator etc but im all a bit new to this stuff so if some one could advise me on what else i need or if anything should be changed that would be great!
- 10x XSPC Tubing Clip For 1/2" Hose
- 1x XSPC Dual 750 Bay Reservoir & Pump
- 1x D-Tek Fuzion V2 Universal CPU Block (To fit AMD 64 X2 4800+ 939)
- 2x D-Tek Fuzion Universal VGA Block (To fit 7900GTX)
- 1x Alphacool NexXxoS Xtreme lll Rev2 Triple Radiator
- 2x DangerDen ClearFlex60 1/2" Tubing - 1m
- 1x Feser One UV Reactive Coolant 1 Litre
- 3x Yate Loon D12SM-12 120mm Case Fan
I would like to have 1 loop to service my 8800GFX & Q6600.
