I mean the ones that are bluetooth. They have a wire to connect the two earphones but its wireless in the sense that you dont have to plug it into the deviceYou want wireless headphones that isn’t wireless?
I don’t think they make them.
Can you recommend the rubber dome type ones?I know what you mean. True wireless would be Apple Airpods for example. Wireless are the type you are describing, that have a cable which connects the earphones and have a small enclosure for the electronics and battery.
I think this is going to be difficult, because most Bluetooth earphones are the IEM type that fit in the ear canal. Very few are the type that sit in your ear and of those, I can't say I've seen any that are Bluetooth; except for the cheap no name brands on the jungle site.
I got these and I highly recommend them - *REMOVED*
I got them at £30 though.
I've also put Comply eartips on them.
Hold on I thought we stopped with all these competitor links if OCUK don't stock the product?
I could well be in the wrong then mate, it’s practically a hobby of mine
Have a look around on the famous auction site
You can type eBay
