- 9 Sep 2020
- Dublin
Hello all
I'll cut to the chase as I merely want a few suggestions on a new workstation.
Reason/workload: Tensorflow Deep Learning applications. I'm currently hitting a VRAM limit on a project and have clearance to build a new machine, the budget is £5k if you can call that a budget.
I basically need advice on previous gen threadripper vs the zen 3 5950x and their motherboards. Think power delivery as stability is essential.
Thanks!
Thanks!
