New X99 build - Irritating whine noise
11 Dec 2003
Milton Keynes
Just finished setting up my new build, all good apart from a constant high pitched whining noise! :(
Initially suspected coil whine on one of the 980s so removed both graphics cards yet whine persisted. PSU is located in it's own half of the case and can't hear anything coming from it - can't for the life of me work out where it's coming from!
Any ideas,suggestions?
Specs :
Case : Corsair Carbide Series Air 240
Processor : Intel i7 5820K
Motherboard : EVGA X99 Micro
Memory : Corsair Vengeance LPX 16GB (4x4GB) DDR4 2666MHz
Graphics : 2x Nvidia GeForce GTX 980 4GB in 2-way SLI
Solid State Drive : Corsair Force Series LX 512GB SATA 3
Hard Drives : 2x 3TB Toshiba DT01ACA300 3.5" SATA 3 in RAID 1
CPU Cooler : Corsair Hydro Series H100i
Power Supply : Corsair HXi Series HX1000i 1000W
The Haswell-E CPUs don't come with a heatsink!
Made a very quick/short video, may have to turn the sound up to hear it (apologies!)
Will investigate again tomorrow, too tired to carry on messing around with it now :D
https://www.youtube.com/watch?v=tCTPuvgAUyM
Noise is constant, doesn't change pitch or volume - audible when standing outside of the room :(
Guess that's the problem with small builds, everything's so tightly packed together it's difficult to troubleshoot!
Sounds like the H100i pump. You could safely unplug its SATA power lead while the PC is running. It will only take a few seconds to identify if the noise is gone and to plug in the lead again. There won't be any massive overheating if it's on idle, and for a few seconds, don't worry.
disable intel speedstep in the bios aswell and see if the noise stops
could be the mb power saving/throttling or psu
