Hi all... Some of you may remember that before New Year I had bought a new cooler. It seems that that thread has now been moved to the private CS forum.. I went ahead and fitted the fan....
http://www.overclockers.co.uk/showproduct.php?prodid=HS-075-ZA&groupid=701&catid=2330&subcat=2355
Using the fan/cooler's 3-pin connector to the MB's 4-pin, as advised here, and by CS.
And now I have, as I feared, a horribly noisy fan which runs at its full speed and noise. Now, I have looked around in the BIOS, and tried enabling and disabling Q-Fan control and Cool 'n' Quiet.I have changed the voltage and temperature thresholds. Nothing slows the fan. The sensors in the BIOS are working. If I slow the fan by braking it with a finger, the RPM figure changes. I honestly cannot work out what might be wrong here... Can anyone advise?
ps, In openSuse linux, and in Parted Magic Live, lm_sensors sees the sensors, including the fan RPM. I don't usually use Windows, but have the tech preview of MSWin 10. Speedfan, again, sees and reports the temps and fan speeds, but I can see no way to change them. It seems to me that if I can't manually affect the speeds whilst at the BIOS stage, then OS tools won't either. My MB is an old M2N-MX, with an Athlon 2 64 5600. The BIOS is version 1004, the latest they released (in 2008!). I have tried running the board with the fan disconnected... (don't try this at home folks!) with the expected results, although the temps reported by OS were not very high before the crash (below 60 deg C).
Could it be that the MB has ALWAYS run its CPU fan at full? The stock AMD cooler was 4-pin
Code:
sp 11:17:~>
sensors
atk0110-acpi-0
Adapter: ACPI interface
Vcore Voltage: +1.14 V (min = +0.85 V, max = +1.60 V)
+3.3 Voltage: +3.34 V (min = +2.97 V, max = +3.63 V)
+5 Voltage: +4.92 V (min = +4.50 V, max = +5.50 V)
+12 Voltage: +12.61 V (min = +10.20 V, max = +13.80 V)
CPU FAN Speed: 2250 RPM (min = 800 RPM, max = 7200 RPM)
CHASSIS FAN Speed: 0 RPM (min = 800 RPM, max = 7200 RPM)
CPU Temperature: +30.0°C (high = +60.0°C, crit = +95.0°C)
MB Temperature: +29.0°C (high = +45.0°C, crit = +95.0°C)
k8temp-pci-00c3
Adapter: PCI adapter
Core0 Temp: +24.0°C
Core0 Temp: +26.0°C
Core1 Temp: +21.0°C
Core1 Temp: +25.0°C
