I’m considering fitting an Amiga motherboard inside a PC mini tower and there are a few bits that your experienced modders can help me with.
I can have a modified backpanel made I can fit with cutouts for the Amiga mobo and some expansions but there are a few more issues to sort:
What sort of thickness of steel should I be using – 1mm?
The existing panel has to be removed. It’s riveted in which means drill them out and should be easy enough.Are those cheap (under £10) rivetting kits sufficient to attach the new back panel?
