- 20 Dec 2007
Hi Folks,
I have a CoolerMaster Elite 300 case that accepts two fans, one at the back and one at the front. I was going to order three Akasa AK-191-SM Smoke Ultra Quiet 120mm Fan - 3 pin, two for the case, and one for the top of a Thermalright Ultra-120A CPU Cooler (Socket AM2/LGA775).
I want to overclock an Intel Core 2 Quad Pro Q6600 "Energy Efficient SLACR 95W Edition" 2.40GHz (1066FSB), hoping for around 3.0GHz to 3.2GHz.
The case will also have two HIS ATI Radeon HD 3870 XT ICEQ3 TURBO 512MB GDDR4's in it.
Can people comment on if this enough cooling for this system? Will I need more powerful fans?
When installing the fans, which way around do I do it? Do I put the fan on the CPU to blow air onto the heat sink, or suck air away? Again, with the case fans do I blow air out of the case, or suck air into the case, or put the different way around so I cause a flow of air through the case?
Thanks for the help in advance!
