Evening everyone new member and new OC here.
I'm building a new PC with an ABIT IP35 Pro running Core2Duo E6600 which i'd like to OC to 3.2ghz with a Arctic Cooling Freezer 7 Pro HS however i'm stumped on case cooling. I don't know wether to go with manual fan controller or get a fan that does it automatically also I understand the auto ones can only be used as exhaust is this correct? Also i've seen ones that have a switch on them but if manual is the way to go i'd like it to be controlled by fan controller that can go in a bay. The case will already have a fan on the side how many more would I need? I'm looking to spend £10 max per fan if I need 3 more. Or should I just get an ABIT guru to control them? I'm so confused please help.
