Newbie - First build opinions
9 Mar 2021
United Kingdom
Hi all,
I've decided to 'venture out and try to build my first PC. I wanted to get some advice/opinions on the build. Due to GPU market being crazy I've had to skip the GPU (I'm guessing that a stupid thing to do?) and will purchase one when the market returns to some normality, whenever that is.
I've had a tight budget of £850 on the build, but will have no budget for the GPU when the time comes. I'm plannjng on using the PC for basic gaming, mainly MMORPGs and maybe in the future look to start playing the popular games like CoD etc.
As this is my first build I have no doubt there will be some negative comments however as I'm still learning any constructive advice would be grateful.
CPU - Ryzen 5 3600
Cooling System - Raijintek Eos RGB Rainbow Complete Water Cooling 240mm
GPU - N/A
Motherboard - MSI MAG B550 Tomahawk (AMD AM4) B550
RAM - Corsair Vengeance RGB PRO Black 16GB (2x8GB) 3600 MHz AMD
SSD - WD Blue 3D NAND 500GB M.2 2280
PSU - Corsair RM Series RM650 650W '80 Plus Gold'
Any advice on a GPU that would suit my build would much appreciated.
Thanks in advance.
The nvidia 3060ti/3070 or AMD 6700xt/6800 are balanced new series gpu for that build.
Have you thought about getting an intel cpu like the intel 11400 instead of the 3600 so that you can get a picture out while you try to find a gpu?
You might find old MMORPGs like Lord of the Rings Online playable on the built in graphics on the 11400 while you wait to get a gpu?
