Newbie Media PC HELP
9 Aug 2010
Hello,
I am new to media pc's and stuff but I have built pcs before just not in a small factor, sorry if i'm doing something wrong. I am needing a dedicated pc which will stream movies/songs to XBMC from a external HDD (NAS)
Would it be better building a media pc in a small factor case or buy a revo 3700?
What do you think?
What storage is recommended for something that I need?
I would say build one, I'm not a big fan of Atom, but the D525 is dual core. Go with an i3 setup, also the options there to install a Linux distribution to keep costs down.
Revo is good but limited to 2.5" HDD so no big HDDs.
Get an Ion ITX and you can stream to others and run XBMC too ;) MM is your friend!
Is this capable for a HTPC?
Lian Li PC-Q08B
Gigabyte GA-H55N-USB3 Intel H55
Intel Core i3 550 3.20GHz
Corsair XMS3 4GB
Samsung SH-B123L/RSBP 12x BD-ROM / 16x DVD Writer Drive
Hitachi Deskstar 7K3000 3TB SATA 6Gb/s 7200rpm
Corsair TX 650W ATX SLi Compliant Power Supply
and I see many htpc related threads ask what tv turners they should get? what is that good for?
if you get tv tuners you can use your htpc like a sky + box and record tv on it :)
that spec you listed is total overkill for just streaming media and as Methanoid said a dual core atom with ion chipset would be up to that job or if you want a little more ooomph even a skt 775 itx board with something like an e21XX pentium dual core would be ideal.
i3 is a dual core, what do you think about this? What PSU is needed to run this system?
yeah i3 is dual core but way overpowered for you your wanting to do :)
you could get something like the zotac 9300 itx skt 775 board and pick up an e2180 or something similar for £20 second hand :)
even a good quality 400w psu would be fine with that build
