- 13 Jan 2006
Hello people,
I've been having problems with cooling. Although i'm not an overclocker i would be interested in learning how to do it properly. I know there are risks involved and i wouldn't be comfortable trying it unless i was 100% confident.
Anyhow, my problem is with a system that isn't even overclocked!
idle temp= 62c, load temp= 70c+,
i don't use the system for gaming. Mainly for browsing and burning movies.
its when im burning movies i get temps of 70c+. Blue screened a couple of times and rebooted on its own while encoding movies. That is what got me worried. I know now that 70c+ is not a safe temp.
I have taken one of the panels off in an attempt to help cool. Also bought compressed air in a can and cleaned out all the fans but still only a slight change. I know that if i go into the bios and drop the FSB to the lowest it will help, but then im sacraficing performance.
What i need is a simple and inexpensive way to cool the CPU.
(Take into consideration that im a virtual beginner and can just about fit a grapghics/pci card on my own.)
Some info on my (humble)sytem below -
CPU Type AMD Athlon XP, 1733 MHz (13 x 133)
Motherboard Name Gigabyte GA-7N400-L
Motherboard Chipset nVIDIA nForce2 Ultra 400
System Memory 1024 MB (PC3200 DDR SDRAM)
Video Adapter NVIDIA GeForce 6600 GT (128 MB)
Disk Drive ST3120022A (120 GB, 7200 RPM, Ultra-ATA/100)
Optical Drive JLMS XJ-HD166S (16x/48x DVD-ROM)
Optical Drive PIONEER DVD-RW DVR-107D
benchmarks:
CPU Clock Motherboard Memory
1733 MHz Gigabyte GA-7N400-L PC3200 DDR SDRAM
Read Speed
1832 MB/s
write speed
733 MB/s
latency
158.6 ns
benchmarks:
Read Speed
1832 MB/s
write speed
733 MB/s
latency
158.6 ns
As for cooling, what's your case like? Does it have sufficiant fans? Tidying up the case inside can also imrove airflow.
Not with those temps on that cpu surely? Maybe a hsf with a broken fan?
! Admittedly, there are no case fans or anything on it. As I don't use it often, I have only just realised that it actually does this, so I am replacing the heatsink on Mon.
