Hi all Newbie OC alert
After building my system a while back with the intention to try some overclocking, I never actually got round to trying it. was pleased at the time with the peformance of my rig/7800GTX etc.
After buying a 8800GTX and getting some poor benchmark results I decided to give it a try. In 3dmark06 I got 6111 which to me seems very poor even for my CPU?
Can anyone add any advice on my next move
Have i overclocked it correctly so far?
Stock temps are - CPU idle 29 load 34-35 sys temp 34 Chipset 34
Spec.
A64 3700+ San diago (+Thermalright XP-90+92cm fan)
DFI Lanparty SLI-DR. (+Thermalright HR-05 SLI chipset cooler)
2GB Mushkin PC3200, Blue heatsink version. (2x1gb sticks) at 1T 2.3.2.5
XFX 8800 GTX (at stock speeds.)
OCZ Gamer X stream 700watt PSU.
WD 250Gb SATA2 HDD.
Audigy 2 ZS.
Windows XP-Pro SP2.
Akasa Mirage case with very good airflow & very cool.
2x Scythe 120mm fans "1600 rpm" inlet and exhaust fans.
Overclocked it after reading the beginners post.
I left all the voltages standard apart from memory which I have at 2.7volts.
I just increased the FSB and got the following result stable.
CPU 2751 mhz (Idle 30c load max Iv seen is 38c)
HT link 1250.551 mhz
Memory 500.221 mhz (ddr)
FSB 250.07 mhz system temp is around 38-40c at load.
CPU multiplier x11
Memory ratio 1:1 (not sure what this)
PCI-bus locked at 100 mhz
CPU is set to 1.36 volts (is this right seems low)
Once I lowerd the timings to 3-4-3-6 it runs stable
Ran 3dmark06 and got 7436 a lot more than before and getting better Fps
Does my score now seem about right or is it still lagging.
Sorry for the long post all, and thanks in advance.
Spec.
WD 250Gb SATA2 HDD.
Audigy 2 ZS.
Windows XP-Pro SP2.
CPU multiplier x11
