Dear all,
After a bit of close lurking on this here board, I'm now taking tentative steps to embarking on my own OCing hobby. I was wondering if I could call on some of you experts for a bit of advice. My current rig is as follows:
AMD Athlon 64 3200+ Venice
ASUS A8N-E Motherboard
BFG Tech GeForce 7800GT
4 x Kingston KVR400X64C3A/512 RAM
Everything has standard stock cooling. Now, I've just placed an order for the following from OverClockers:
DFI LanParty UT NF4 Ultra-D (Socket 939) PCI-Express Motherboard
Zalman CNPS9500-LED Aero Flower (Socket 939/754/478/775) CPU Cooler
Zalman VF700-CU Quiet Copper VGA Cooler
I've also kinda built a plan around what I've bought and what I plan to buy in the future and I just wanted to check that I haven't missed anything, but at the same time making sure that I'm not taking on too much at once.
Obviously, tomorrow will consist of installing my new motherboard and CPU cooler, then re-installing windows (XP Home Edition). No doubt I'll probably fit the new cooler to my graphics card since it'll be taken out anyway.
My first step will be to start overclocking my CPU. Thanks to the pinned guide at the top of this board, I've had a go on my current setup. So far so OK - I've had some increase in performance - only I'm now being beaten for heat (hence the new coolers).
I've noticed that the VGA cooler pack comes with some RAM heatsinks. Next month, I intend to take out my current RAM and replace it with G.Skill 2GB DDR HZ PC4000 (2x1GB) CAS3 Dual Channel Kit. Would it be worth attempting to fit these heatsinks to my current RAM in the mean time? I'm told that Kingston RAM isn't the best for overclocking with - especially since it's 4 sticks of it. Would this be the case? Would I be best just to wait until I get my new RAM before fitting these heat sinks?
The next part - once the CPU's been OC'ed to a stable level - is to have a go at my Graphics card, which I don't have a clue about as yet. I'm in absolutely no rush to get any part of this finished. I'm just now keen to start having a go at overclocking a system. I've been building my own systems for 7 years now and haven't attempted to overclock one of them until this week.
Sorry if I've missed any detail to this. I'm just wondering if I'm going about this the right way? Should I give the overclocking a serious go with my current RAM or wait until I get the G.Skill stuff? Any advice would be most appreciated.
