Recently bought an aftermarket cooler for my Q6600.
Ended up going for a Noctua U12P as I was wanting to reduce noise, as the stock intel cooler sounded like a small aircraft powering up.
Just going for a modest overclock, 2.4 to 3.0. Here are my specs
Asus P5K mobo
Noctua NH-U12P cooler
NZXT Hush case (yes I know its a bit cramped in there)
Q6600 overclocked to 3.005 MHz
Core Voltage (left @ auto) 1.32v
Corsair DDR2 XMS2 4GB 8500C5 @2.1v /DRAM Freq 534 /FSB: DRAM 5:8
Here are the results on CPU-Z
Cores are running at 46-50 C idle topping out at 62 C at max load. ( temps from Core Temp v0.99.5, stress test on OCCT attached below)
BUT, if I open the case, temps drop by some 8 degrees! Is this normal?
Here are the temps with the case open and closed
All stable after 2 days but I don't know if I should push it some more I'm not happy with those temps going higher.
Any thoughts? Should I have kept the FSB: DRAM at 1:1 or was I right to change the RAM dividers, seeing as the RAM is rated at 1067?
Asus P5K mobo
. What's your V-core? Idle temps seem very high.
. I have room temp 33C and a Small Form Factor case and this cooler ZALMAN CNPS8700 LED.
