Hello all, as you can see, it's my first post here so go easy on me! I've been an ocassional reader of the forum for a couple of years now, since building up my machine at the end of 08. At the time I think it was a decent build- Q6600, 4GB ram (800mhz), GA p35 DSL and a GT8800 GPU.
It's been pretty bloody solid... Until recently! For the first time it couldn't cope with something I threw at it - blue ray rip (1080p), 40GB worth of it! So, I decided that I'd prefer to do as much as possible to improve the performance without spending (too) much.
Having read about overclocking in the past, and monitoring my temps I knew I needed to get rid of the stock cooler so ive got an Arctic freezer 7 Pro and a couple of extra case fans.
So, the OC. Currently I'm running at 3.18GHz - FSB 353 x 9. It feels fairly stable here, it stands up to OCCT CPU test for as long as I've run it - 3-4 hours, and prime blend for just as long. However, if I knock the FSB up just 1 click it errors or BSODs within the hour on OCCT, and any higher it bluescreens very quickly. The above is with 1.44 Vcore before OCCT starts, and drops to 1.38-1.4 when it startS testing. (anyone explain this? Resistance in the cores as temp increases?)
Throughout all, the core temps don't go beyond 66C.
So, what I'm asking is where would you guys take it from here.?I've heard that's 1.5vcore is OK, but also that 1.45 is tops, and some people wouldn't go that far on a Q6600.
I'm thinking I might back it down to 3.15GHz, and then start dropping the Vcore until just stable.
But I'm brand new to this all, and would love your advice!
Secondly, one of the first things I had problems with was my RAM speed. The "memory multiplier" was set to auto, and as a result, my RAM was running up past 1000 MHz. Now I've got it on a multiplier of 2, which is a 1:1 divider, or so I've read. It's running at 706 now, so below it's stock. 2.4 is the next option, which would run it well above stock. What's safe, and what's not? And can someone explain in layman's terms how RAM interacts with the CPU?
Sorry for the endless post, but I'm sure there's a lot of guys on here who will look forward to helping me out.
Thanks in advance guys, Ben
