I tried to instal some software and my pc crashed. I had to switch the power off at the PSU (Tagan 580 easycon). Now, it won't start up again. Absolutely nothing. My motherboard is a DFI lanparty ut DR200 Crossfire. I've reset the CMOS jumper, and the m'board power reset switches with no luck. I thought it must be the psu, so I took it out and plugged the ATX socket onto and old motherboard, which worked...
Not sure if there is some obvious setting on the m'board I'm missing, or if the PSU really is screwed, but it seems strange that it can power up the m'board on my old pc.
Any help gratefully received, as I've run out of ideas...
Thanks
Mark
AMD 3800+ X64 dual core
X1800XT - (pair of)
Lanparty 200 DR Crossfire
Tagan 580 Easycon
Corsair 3500LL Pro 2048MB matched pair
Audigy 2 ZS platinum pro
Western Digital 320BG sata
Thanks
Mark
X1800XT - (pair of)
Tagan 580 Easycon
