hi
i just brought a new pc off gumtree, and it looked fine but on going into bios i noticed cpu temp alarm was disabled, so enabled at 70c and started running a stress test within minutes the alarm was going and i looked at pure temp and it was over 80c , playing left for dead 2 also caused this... so i figure the stock heatsink is the problem.
I want to fit a new heatsink but i dont know which one, the case is an X-Blade 10-Bay Aluminum Mid ATX Gaming Case
so i need one to fit that,its fairly large so i think i'll be okay with most but not sure...
the other key factor is price, i doubt i'll overclock as im too scared to break it , and if i did it only be to 3ghz.
actually thinking theres two more issues too, how do i remove stock heatsink? the thermal compound is it worht buying the remover? and what shall i use with it and in fitting the new one do i HAVE to remove motherboard, to fit the mouting stuff as before i used artic 7 freezer pro or something and it was just a clip based one... is it difficult?! sorry newbie and dont want to break anything if I dont have to by removing motherboard..
Thanks in advance!!
Thanks in advance!!
