Orignally thought about going for a 360 AIO for my 3700x but was persuaded to go whole hog, so some of you may say this is overkill for just a CPU, but my reasons are that my GPU temps are perfectly adequate and that I'm happy with. I also like to chop and change equipment really, and the card is still in warranty so I may consider watercooling the next gen GPU that i add in, not absolutely sure yet, but made sure to include enough cooling power and pump pressure for doing so should I wish to add in future..
This is from a guy who hasn't done a proper custom Watercoop before so bear with me, doing the best i can. I want to keep it aesthetically pleasing but didn't want to bother with hard line tube. Some of the bits are mish mash as that's Whats I had left over form previous builds that had been stripped down for parts.
Here's as far as Ive got so far:
Its a Thermaltek Core V71
3700x
32GB Ram
Asus 1080Ti
Asus Crosshiar VII Hero
So getting there, but still a way to go yet, open to questions suggestions and Ideas,
3700x
32GB Ram
Asus 1080Ti
