Newbie to overclocking.
20 Nov 2006
Hi ive just received and built my pc and now want to overclock it for max performace. How do i do it ! thanks.
This is what i got inside.
Intel Core 2 Duo E6600 "LGA775 Conroe" 2.40GHz (1066FSB) - Retail
Noctua NH-U12F (Socket LGA775/754/939/940/AM2) Heatsink
Gigabyte GA_P35C_DS3R (Socket 775) PCI-Express DDR2 & DDR3 Motherboard
Crucial Ballistix 2GB (2x1GB) DDR2 PC2-5300C3 667MHz Dual Channel Kit
Corsair HX 640W ATX2.2 Modular SLI Compliant PSU
Yeah, check the stickies. You have some nice gear there, so should get a decent clock. If you have any problems just post back, i'm sure someone can help if you need it.
It should be, but get your cpu overclock stable first. I overclock my 8800 using ATI tool, but there are a few programs you can use for this.
