Newbie Watercooler!
22 Jun 2010
Hi Guys,
New here but hoping for some good advice.
Just bought a Phenom x6 computer, and an ****** 360 watercooling kit, all fitted and running.
But the PVC hose (10mm/8mm) is not flexible enough for me, even with anti-kink coils on it.
My main question is : is Silicon Tubing a more viable solution than PVC - I can get this size in silicon but I wonder if it will react with the cooling fluid, or perhaps not fit as nice on the compression fittings.
Thanks in Advance
Silicon is not the way to go, it doesn't react well and breaks down (from memory...).
The usual stuff from someone like Masterkleer, XSPC etc will be good.
