Hi guys, I just came home from work and had a delivery today of some new case fans & some cable tidying kits & a SATA cable.
So, fitted the fans, tidyd some cables. go to turn the pc on and i get (disk boot failure, insert system disk and press enter)
So, i panic'd and thought **** (as you do)
Rebooted. same error so i googled the error message
Ppl suggested changing the boot device priority [HDD] , [CDROM] etc...
Tried it, nothing..
The pc worked FINE yesterday..
Also i dont have XP on a disk, but could get it
(Also im no pc wizzkid so please try and keep it simple as possible
Tried it, nothing..
