- 27 Mar 2004
- Between Realities
Is there one for use with Ubuntu?
Thanks if anyone knows of one.
nzbget is good, it doesnt have a GUI though.
theres also hellanzb, ninan (which is great, works over http), nzbperl and sabnzbd.
IMO none of these apps are quite up to the standards yet of their windows equivilants sadly.
I would suggest trying all the above till you find one you get on with, or you could try running Newsleecher under Wine![]()
