Newsleech problem. How to make folders for each download?
18 Oct 2002
Earth
Hi all
I've just bought a copy of Newsleech i've always used Grabit but this seems a lot better and has a good speed feature i use.
However i've got a problem that i never had with grabit and i can't work out how to solve it.
When i download something it puts in a folder like this alt.binaries.multimedia but inside it theres just rars and not another folder of what the title of the download is. In Grabit it use to name a folder 27363543_whatever_the_name_was, then download all the Rars and nfo to this folder.
Is there a way to get this to happen and if so how please??
Thank you.
I don't think you can with Newsleecher - it only creates folders per group, not for articles inside.
What I'd like to see in a future revision is the capability you asked about which probably comes from having a threaded view whereby it groups multi-part downloads into a single thread so you can easily see.
try using Ninan, web based and it will put each download into a separate folder. It will also unrar and par check the files automatically aswell.
