Newsleecher - help needed
28 Dec 2009
Wales
I am running Newsleecher and regardless of whetehr I have one item or several in the queue I leave it going only to find out that the download has paused at about 75%. Anyone else had this and how do I get around it?
Are you running the 5.0 beta or v4 final?
Disk space an issue? It pauses the queue when space reaches a certain threshold (changeable in settings)
Does the log in newsleecher say anything?
If you are using a disk that doesn't contain your OS does it turn itself off for power saving?
I think that may have done it, though I can't imagine it would have hibernated the drive while writing to it...... maybe it was giving it chance to catch up....
Glad its sorted anyway. I used to download to an external that would turn itself off. That's how I knew what the problem might be.
