- 12 Oct 2003
- Leicester
Hi, anyone know a good newsreader for mac. Hopefully one that repairs and extracts automatically.
Thanks
Thanks
I used so many usenet clients to find one i was happy with and to be fair, i havn't found one which is a good as newsleecher.
Saves a lot of time! Plus, it is easy to use, try it and you'll see!
SABnzbd for osx is basically a daemon running in the background, you connect to it via your browser, load up your nzb files, it can automatically put them in named folders, par check, par repair and then extract.Saves a lot of time! Plus, it is easy to use, try it and you'll see!
No probs dudeThat sounds promising, thanks very much!![]()
It's quite straightforward, but if you have any probs, let me know. It's an awesome prog but not many people seem to use it :S
