Next best thing after a TRU120?
8 Jun 2006
Hertfordshire
As above guys
I have the TR but the temps on my (3.6ghz) E6600 at idle are 47 and load 65 :eek: the chip is lapped and I lapped the HS but my overall temps went up 5c after lapping, my mates going to buy it off me and re-lap it as I can't be bothered with that stuff I'd rather just pop it on and thats it :)
I have a 120mm 1600rpm fan spare just incase the unit I buy doesn't come with one but is the Noctua NH-U12F CPU Cooler (Socket 754/939/940/AM2/LGA775) the next best thing? The titan is probably a bit too pricey for me really?
Or the Scythe Ninja Plus Rev.B CPU Cooler
Or
Tuniq Tower 120 CPU Cooler (Socket 478/754/939/940/AM2/LGA775)
Thanks guys
I'd recommend (and use myself) the Noctua for low noise and low temps at stock speeds but I think the Tuniq is likely to be the next best for overclocking.
Yeah I thought as much, I will be overclocking so............
Just worried that I will have to lap the TT120 ? But I haven't seen a lot of ppl if any say they had to do their?
OcUK hasn't got them in stock though :( will have to go elsewhere.....
