How about HP ZR24W? It's definitely not the fastest monitor, but at least the image quality should be outstanding. Depends how serious you are about gaming.
There's absolutely nothing wrong with a 16:10 monitor for gaming. A lot of people run a resolution of 1920x1200 for gaming. Myself included and it's amazing![]()
I have reliable info from a Dell employee that the so called 'U2412HM' doesn't exist. H denotes 16:9 aspect ratio.
There will be U2312HM and U2212HM monitors for those that prefer 16:9.
Where dig that BS up from16:10 monitor for gaming is no good choice.
Loads of people have been using 16:10 monitors for gaming for years...
You had 7/8 years or so with a monitor that was released in 20077/8 years or so with my older 2407 and no problems either, it's just BS... simply put![]()
this will probably please many, but ive confirmed 100% that the U2412 will actually be called the U2412M (not U2412HM) and WILL be 1920 x 1200, 16:10 aspect:
http://www.tftcentral.co.uk/news_archive/24.htm#dell_u2412m_specs
@Locke. Get the facts before spreading misleading information. The problems with no 16:10 support is primarly a thing from 2011 and later so what you did 7/8 years ago is totally irrelevant.
There are plenty of games from 2011 that doesnt have 16:10 support. Witcher 2, Assassins Creed Brotherhood, Bulletstorm, Alice Madness returns, Dungeon Siege 3 and so on.
Still though 16:9 works better with most games released the last 5 years even if the game support 16:10 because you get smaller Field Of Vision using 16:10. So for gaming 16:9 is a better choice for sure.
