Next Level Racing Simulator - New Range
OcUK Staff
23 Feb 2015
Overclockers UK HQ
Hi all,
I wanted to get some higher quality racing sim peripherals with the explosion of VR: The Next Level Racing Simulator range allows racing sim enthusiasts to build a professional grade simulator piece by piece or buy one whole (while allowing those without the space for a full simulator to still have quality peripherals for their racing sims). With the flight sim add on pack the simulator equipment will also cater to flight sim enthusiasts.
We will be adding to the range over time. Let us know what you think below :)
Next Level GTultimate V2 Racing Simulator Cockpit (NLR-S001) @ £599.99 inc VAT
Leading the way in design and functionality the Next Level GTultimate V2 is a cockpit that not only home users can afford but a cockpit professional racecar drivers from numerous racing leagues rely on to help improve their times on the track. As well as being used by thousands of sim racers from around the world the GTultimate V2 is used by drivers from numerous racing series including V8 Supercars, Dunlop Cup, Kumho Cup, Swift Series, Aussie Racing Series, Formula Ford, Porsche Cup & More.
Leading Features of The GTultimate V2:
Completely Adjustable Wheel, Gear Shifter and Pedal Positions
Patented design allows cockpit Separate into two halves and folds for easy storage
Rock Solid Cockpit weighing approx 45kg
Built for extreme comfort with custom reclining fibreglass race seat including lumbar support cushion and even 4 point racing harness
Numerous accessories to build your ultimate cockpit
Compatible with all major wheel and pedals. Pre-drilled for Logitech, Thrustmaster and Fanatec wheels
Specifications:
Supported Height - 120 cm Children to 210cm Adults
Supported Max Weight - 150KG
Product Dimensions -L 125-150 x W55-70 X H 117CM
Product Weight - 45KG
Boxed Dimensions -87 X 66 X 58 CM
Boxed Weight - 48KG
Part Number NLR-S001
What’s In The Box:
Next Level Racing GTultimate V2 Racing Seat and Frame
Next Level Racing Lumbar Support Cushion & Four Point Racing Harness
2 x gear shifter adaptors/holders that vary in angle based on your preference
Velcro Ties for cable management
Screws to hard mount your wheel
Instructions for quick and easy assembly
Compatible Next Level Racing Products:
Next Level Racing Motion Platform V2
Next Level Racing Monitor Stand to support 1 x 55” screen or 3 x 30” screens
Next Level Racing Keyboard and Mouse Stand
Next Level Racing Gaming Desktop
Next Level Flight Pack
Next Level Floor Mat
Any game controller, monitors or other accessories including floor mat sold separately.
Only £599.99 inc VAT.
ORDER NOW
Next Level Racing Wheel Stand (NLR-S002) @ £199.99 inc VAT
The unique and market leading design of the Next Level Racing Wheel Stand makes it a rock solid solution to have your wheel, pedals and shifter all in a realistic racing position. The stand can fold in less than 5 seconds to be packed away and be stored when not in use. The perfect solution to enter the world of sim racing, you can start with the Wheel Stand and keep building to a complete Next Level GTultimate V2 Motion Simulator Cockpit.
Leading Features of The Next Level Racing Wheel Stand
Completely adjustable wheel, gear shifter and pedal positions
Patented design that is rock solid, yet folds in only seconds
Allows everything to be in a realistic racing position with no annoying pole between your legs
Comes almost completely assembled
Specifications
Supported Height - N/A
Supported Max Weight - N/A
Product Dimensions - L 64 x W 55 x H 60-80CM
Product Weight - 15KG
Boxed Dimensions - 64 X 15 X 74 CM
Boxed Weight - 19KG
Part Number NLR-S002
What’s In The Box
Gear shifter adaptor/holder
Velcro ties for cable management
Next Level Racing Seat Add On (Converts Wheel Stand into GTultimate V2 Racing Cockpit)
Steering wheel, joystick and other items sold separately
Only £199.99 inc VAT.
ORDER NOW
next level flight pack (nlr-a003) @ £49.99 inc vat
transform your gtultimate simulator cockpit into the ultimate flight simulator cockpit to mount your flight joystick and throttle on either side of your seat or even between your legs for helicopter mode. the flight pack can also been used with the next level racing wheel stand to hold your flight joystick and throttle on either side of you.
leading features of the next level flight pack
compatible with all major flight controls including saitek, thrustmaster and ch products
get your flight gear in realistic positions to take your flight simulation experience to a whole new level
specifications
supported max weight - 20kg
product dimensions - n/a
product weight - 4kg
boxed dimensions - 55 x 20 x 10 cm
boxed weight - 5kg
part number nlr-a003
what’s in the box
next level racing flight stand parts
instructions for assembly
compatible next level racing products
next level wheel stand
next level racing gtultimate simulator cockpit
next level racing stand, flight controllers and accessories sold separately
only £49.99 inc vat.
ORDER NOW
Next Level Racing Floor Mat (NLR-A005) @ £29.99 inc VAT
The Next Level Racing Floor Mat is a great addition to your wheel stand or cockpit. Add the final piece of the puzzle in terms of look and protecting your floor. The Next Level Racing Floor Mat has an anti-slip layer on the underside and is finished with an embroidered logo on the mat.
Leading Features of The Next Level Racing Floor Mat
Perfect to protect your floor
Anti-slip underlay
Specifications
Product Dimensions - L 165 x W 60 x H 0.3CM
Product Weight - 2KG
Boxed Dimensions - 60 X 10 X 10 CM
Boxed Weight - 2KG
Part Number NLR-A005
Next Level Racing GTultimate Simulator Cockpit
Next Level Flight Simulator
Only £29.99 inc VAT.
ORDER NOW
That flight pack one is really tempting. For the likes of Flight Sim X, Elite, and Star citizen which I play often, £50 is cheap for that.
Just need actual flight sim controls first :P
I have the Saitek X55 Rhino, is it just screws into the underside of each joystick to attach it?
The flight pack does not include the stand, merely the parts you need to adapt the Next Level Racing Wheel Stand for flight sim usage. The joysticks should just screw on to the adapter plates:
RMA? hehe
do they not have them on show in store?
The usual 14 day unwanted returns policy still stands. All you would have to pay is the return postage (although that wouldn't be inconsiderable for an item this size and weight).
We are hoping to have one in store soon if you can make the trip to Overclockers HQ :) Even if we haven't arranged one by then you could always try our VR room XD
It's the Next Level motion platform thingy I'm trying to have a go on. All very nice reading reviews but for £3k I'd like to try it first! Will ocuk have that too?
