- 21 Oct 2004
- Wales
Well now I finally have my Crucial M4Raid up and running, the next part of my computer that I want to upgrade is the CPU cooling. I am currently using a CM Hyper 212+ with a i2500k currently clocked to 4.4GHZ on 1.325V with average gaming temperature's around the 61oc mark. Unfortunately however due to my motherboard, I am having issue's with clearance for the RAM which I want to upgrade very soon so I have decided to move onto one of the all-in-one liquid coolers to clear up the area and possibly get some better temps.
Now my needs are simple, the cooler has to be quiet, on par at least with the CM 212. I had a problem before with a CoolIT ALC where the vibrations were creating a very annoying harmonic throughout the case and as such I would like to find ways to minimize if not completely eliminate the vibration ( I assume from the pump ). I do not have a problem with buying new fans for the ALC itself so you can take that into the equation. My current case is an Antec 300 which I do not mind lightly modding if it helps reducing the noise aspect of the new cooler. My budget of course is 115 but it can be stretched further if needs be.
Any suggestions are welcome in regards to this planned upgrade and I welcome all your advice
