Next size down from 7/16 - 5/8?
OCP
OCP
7 Apr 2007
London
bit confused with the fitting numbers, been a while since I had a look.
Which is the next one down from 7/16 - 5/8? I find this size is a bit too big and hard on bends, I want to go the next size down so I can have more flexibility. Could someone point me to the right ones? I found out after that 7/16 fittings are not as popular and some manufacturers don't use this standard. Is the next size down more widely compatible? I wanted to use the Clearflex tubes but they don't have 7/16 - 5/8.
