Next step from 2 x GTX480's
12 Sep 2005
Grundisburgh
What would be a suitable step up in performance? Is there a single card solution or would two cards be a better or cheaper option.
Both cards are water cooled and I would want to keep that.
Andi.
Would definitely wait to see if anything coming in the next little while is worth while - 680/7970 isn't going to be really worth it coming from that setup unless you can get a good price for the 480s.
Two 770's assuming the rumors are correct. Either that or go for 2 X 680's second hand. I'm sure there will be a few highend watercooled setups which will be going cheap.
It looks like the 2 x 480's perform as well as a single 680, so there's no point in that route, will wait to see what the comes next or whether 2 x 680 is the way to go.
Andi.
I imagine a single 780 would just outperform 480 SLI so might be worth getting two of those when they are out.
Not by allot actually, if at all. The Titan performs a bit faster than the 7970Ghz edition and if these benchmarks are anything to go by 480SLI is not far off 7970Ghz performance. We know that the 780 is a cut down version of the Titan so I really don't see much gain for the OP unless he wants a very fast single card.
Only upgrade path I see for the OP is SLI/Crossfire. Bang for buck this is going to be 7970 Ghz edition crossfire or 770 SLI (depending on prices).
the only way to beat that by almost double for under £500 is 2 second hand or members market 7970s overclocked to 1100+ for £250 each.
keep your cards for a while for the outlay over the performance not really worth it at moment
your cards will be 680gtx slightly quicker maybe area.
id wait for next range of cards.
