Hi,
Could you please advise me regarding the next possible upgrade? I am currently running Win 7 on below specs:
Core 2 Quad Q9505 @3.83
4GB DDR3
Samsung SSD Drive
Asus P5Q Pro motherboard
Radeon 5850 1GB
PSU – Corsair 750 Watts
Case: Silverstone fortress
I am trying to get some possible upgrade steps together for gaming on my 24inch screen 1080p. I don’t need 100+ fps but just need to run games smoothly. I must say it kind of works ok now but with some exemptions: Witcher 2 runs on high in 1080p but has problems on Ultra settings, same for Skyrim but that one tends to drop the frame rate at times.
The questions are:
Can I still upgrade the graphics card and get some real gaming performance improvement?
If so, what card do I need to buy to play in 1080p? (Could afford up to R9 280X but don’t want to spend the money if I don’t need to)
Drop that graphic card upgrade and start from Overclocked motherboard bundle and if that’s the case what’s the reasonable bundle I don’t really need to overspend on?
Thanks a lot in advance for all possible helps and opinions
4GB DDR3
Samsung SSD Drive
Radeon 5850 1GB
The questions are:
