Good Morning Overclockers,
I'm looking for a new upgrade, I may as well continue to upgrade as i just spent a pretty penny on my GPU. Don't want anything holding that bad boy back. I'm not too clued up when it comes to computers but i managed to fit the GPU myself. So if you could also tell me if you think it's possible to self upgrade or would it be worth taking it to a computer shop?
My Spec:
Radeon R9 Nitro 390 8192MB GDDR5 PCI-Express Graphics Card with Backplate (Just upgraded)
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor
Gigabyte Z68XP-UD3 Intel Z68 (Socket 1155) DDR3 Motherboard
XFX 650W XXX Edition Modular '80 Plus Bronze' Power Supply
Gelid Tranquillo CPU Cooler (Socket 754/939/940/AM2/AM2+/AM3/LGA775/LGA1155/LGA1156/LGA1366)
Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX) [KHX1600C9D3X2K2/8GX]
250GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive
Thanks again!! You've all been such a great help.
My Spec:
