Next upgrade?
25 Jan 2004
Cheltenham, UK
So end of Jan this year I got a Ryzen 9800X3D cpu all working great, love it
Just wondering what my next upgrade should be upgrading my triple AOC 24" 1080p 144hz Monitors
or upgrading my graphics card from AMD 6800XT
Do i really need to go 4k?
This one looks really nice.
better monitor is the first thing, unless you are playing competitive FPS - the frames you're getting at 1080 with the 9800x3d is probs overkill
The 6800XT is still a decent card tbh, especially for 1440P.
A monitor upgrade is the best way to go, what budget do you have? The Asus isn't bad but I'd consider an OLED for around £400-500 personally, I'm assuming you've the budget given you were considering a GPU switch.
