- 1 Oct 2007
- Hawkes Bay , NZ
Is there an easy way to get ANT+ to work on the Nexus 5? I have a Giant bike with RideSense.
Depends on your definition of easy
If you're rooted, and prepared to spend ~£6 then, apparently, this works:
https://play.google.com/store/apps/details?id=com.z2software.antplus&hl=en_GB
I should say I haven't used it so not 100% sure, but there's a thread on xda that references it, as well as giving some info in general:
http://forum.xda-developers.com/google-nexus-5/general/ant-nexus-5-t2530745
In theory it would also be possible to sort out the kernel/libraries manually but I've not looked that much into it.
