- 10 Oct 2007
- in the arse of england.
will it work? does it have the right cage to mount it on ? or do i need to buy a new block (switching from AMD opty 939)
the pump i have looks exactly like this but without the DD metal and logo (looks like its come off at some point as theres residue left behind or it could just be a clone)
http://www.pctronix.co.nz/images/dd-12v-dd-d5 pump.jpg
Are you switching to a Quad-Core? If so you'd be far better off switching to a D-Tek FuZion or Swiftech Apogee GTX as blocks that worked just fine with single and even dual-cores just don't work efficiently with Quads.
The water block manufacturers are learning all the time and the blocks I'm currently using are light-years ahead of what I had even as recently as this time last year.
The NeXXos was never a top-performing block anyway and I think you would see a big difference with a new block.
I'm going to be clocking a B3 quad with the EK wave you sold me awhile back...it's cooling my e6600 wonderfully. Will be interesting to see how it handles the heat, and I'll probably upgrade to an EK Supreme when I have enough money so we'll see what kind of temp difference it gives.
The NeXXos was never a top-performing block anyway.
Yes it was, it was one of the best in its day.
